eton 90 -rough running after water stall
Old Oct 13, 2004 | 09:26 AM
billyyorkville's Avatar
Default eton 90 -rough running after water stall
Hi Guys! Newbie here with a question about a '02 viper 90 that my son (with my encouragement) put into a small mud/water bog about up to the floorboards. It stalled in the bog, we pulled it out and it started back up but has run rough ever since. I've drained the fuel tank and float bowl, cleaned airbox and filter, cleared the crankcase, cleaned the flywheel-stator assy which was full of mud, checked piston and cyl which looked good with good compression, belts and pulleys were clean and dry when inspected, after all that it still runs rough. Any suggestions? how do I check the timing? Stator?
Old Oct 13, 2004 | 11:05 AM
STUARTFAMILYRACING's Avatar
You need to check the output of the stator. The service manual should have the specs or do some research online. Did you pull the flywheeel? If not, I would. You need to make sure that there is no mud or gunk in there anywhere. I would then lightly sand the flywheel. All of this of course if the stator output is lower than specs. If stator output is normal, try a new plug. Then I would pull the carb and go completely through it. Remove all the jets and blow compressed air in and out of everywhere. Anytime I've had problems because of playing in the water, its usually the carb. But you said that the flywheel was covered in mud, so that raises some question. Hope this helps.
Bill
Old Oct 14, 2004 | 02:54 AM
confusedbuyer's Avatar
oldyeller from Ontario, Canada has posted that the Viper didn't take on water very well, or very deep. he may have gone through similar problems. i'd suggest PMing him. (click on the padlock option to send a private message).
Old Oct 14, 2004 | 08:40 AM
Thanks Guys for the help! I totally removed the stator assy and cleaned it off with electrical contact cleaner. Then went though the carb real good. Cleaned and di-greased all the electrical connections. This all seems to have done the trick. The viper is alive and strong again! Thanks again.
Old Oct 14, 2004 | 11:43 AM
sucks tho, that you have to avoid water up to the floorboards. especially for a quad that seems otherwise perfect.
Old Nov 19, 2004 | 07:48 PM
CRFBoy99's Avatar
Yeah i went thru a puddle on my little brothers eton the other day and it died right in the middle of it. Kinda sucked
Old Dec 1, 2004 | 11:58 PM
yamoto150owner's Avatar
hey billyyorkville, i live in yorkville,illinois to , where do you live???????????
Old Dec 2, 2004 | 12:00 AM
do u live on spring st. ??
Old Dec 2, 2004 | 12:15 AM
Will67's Avatar
yamoto150owner....i live about an hour or so south of you. I have a new Yamoto 150 too...would love to make some comparisons as I have a few issues with mine. Hell I was just through there yesterday!!!!
Let me know if you're interested in comparing notes on these things.
Old Dec 3, 2004 | 12:35 AM
are there any good places to ride around here will67??
