jetless pipe
Old Oct 15, 2004 | 05:39 PM
grizzlysrock's Avatar
Default jetless pipe
I have a big bear 350 and i was wondering what pipe I could buy that woudnt need new jetting because i think it would be too much work because i dont know that much about carburators,
Thanks,
Marcus
-97' Big Bear 350
-00' Kodiak 400
-99' Grizzly 600
Old Oct 15, 2004 | 06:54 PM
maddog56's Avatar
The purpose of putting a pipe on an atv is to allow exhaust to more easily flow out of the engine. This decreased resistance creates hp. In order to get the benefit from this upgrade, you should let more air and gas into the atv. The way to do this is with changing the jetting in the carb.
You can put a pipe on, but if you dont jet it you wont get the maximum benefit from the upgrade.
Old Oct 15, 2004 | 07:02 PM
garyc660R's Avatar
Originally posted by: maddog56
The purpose of putting a pipe on an atv is to allow exhaust to more easily flow out of the engine. This decreased resistance creates hp. In order to get the benefit from this upgrade, you should let more air and gas into the atv. The way to do this is with changing the jetting in the carb.You can put a pipe on, but if you dont jet it you wont get the maximum benefit from the upgrade.
In adding too maddog's good response, without rejetting, there is always the possibility of leaning the engine out, ultimately causing engine failure.
Gary
Old Oct 15, 2004 | 08:52 PM
thewayout420's Avatar
ill add to the 2 good post above[img]i/expressions/face-icon-small-smile.gif[/img]get a service manual and a re jet the carb,its pretty simple..
Old Oct 16, 2004 | 01:43 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you don't need a rejet, the mod is doing you no good! All you would succeed in doing is spending your money.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
