perfromance parts ?
Old Oct 16, 2004 | 09:54 AM
86250SXrider's Avatar
Default perfromance parts ?
does anybody kno where to get performance parts for an 86atc250SX like jet kits exhaust pipes etc..
Old Oct 19, 2004 | 07:48 PM
conig's Avatar
jet kits don't exist, you can order individual jets. a dial a jet is also available( I've never tried it) the only exhaust I have seen is Cobra. I've seen cams at the link to follow. they make pistons and I have heard of some getting 350x carbs.
http://www.jlatvproducts.com/catalog/cams.htm
Old Oct 19, 2004 | 07:58 PM
thanx man ive heard of the cobra pipe and i saw a 300 piton kit for the SX but i dident kno about the cam so i checked it out and found out they made valve springs so thats cool so if i put all this gear into the bike will i have to beef up the rear end or the bottom end of the motor ?
Old Oct 20, 2004 | 02:02 PM
conig's Avatar
thats unfortunatly somewthing I don't know. my big red is stock(same motor). I don't think theres much you can use to beef up the bottom end. unless you were running crazy compression I wouldn;t see it being neccasary. Same thing for the rear end. You will be limited with what you can do with the 250sx because of the rear end, its strong and shaft driven but is geared low (my big red s lower still).
I have heard a trx300 swingarm will fit for a plus 4 or 6 inch swing arm and probably has different gearing.
check out 3wheelerworld.com and search for 250sx.
Old Oct 20, 2004 | 04:01 PM
thanks for all the info but what trx300 are u talking about the 4 wheel drive fourtrax?and isnt it the same motor in my SX thats in ur big red ?
Old Oct 20, 2004 | 06:19 PM
conig's Avatar
my uderstanding is it is not the same motor. I assume the jug is defferent at the least but I have been told they aren't. As for the swingarm myself
http://www.3wheelerworldforums.com/s...ad.php?t=24682 sorry it was a trx 250 untility rear end.
theres some good pics in this thread too.
Old Oct 20, 2004 | 07:15 PM
ok thanx for the info again but i dont think im going to be too worried about getting that style rear end unless mine blows up or something lol ,what do u mean by race cut platics ? for ur big red are they aftermarket or did u do it yourself?
Old Oct 21, 2004 | 01:08 PM
conig's Avatar
the race cuts are on my scrambler. the big red is basically stock. It has a new snorkel on the air box and it has a cobra exhaust pipe.
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
