Shaving fenders
Old Oct 18, 2004 | 03:19 AM
DGpolaris2346's Avatar
Default Shaving fenders
I was just wondering if i used a hacksaw to shave my fenders and then get some sandpaper and sand the edges if it would look good? Also does anyone have any tips to make it easier? I dont wanna shave to much off but enough to get rid of the holes where the mudflaps bolted to because i removed mine. I plan on doing this tomorrow so any help is needed. Thanks
Old Oct 18, 2004 | 03:29 AM
Sidewinder500's Avatar
Use some tape to make an outline to shave at so that you are relatively straight and not trying to straighten it out afterwards. I have also heard that a heat gun or lighter afterwards will help round the edges out to make them look almost factory edges when you are done.
Old Oct 18, 2004 | 03:48 AM
Alright thanks. You think a jigsaw would work better than a hacksaw?
Old Oct 18, 2004 | 07:04 AM
paulzaho's Avatar
I used a dremel to cut mine. Worked very well. Just make sure you have an extra battery charged before you start. Nothings worse than running out of juice half way through.
Old Oct 18, 2004 | 07:09 AM
I would think a jigsaw would personally work better than a hacksaw.
Old Oct 18, 2004 | 11:20 AM
OneBadPolaris440's Avatar
you can use a roterzip ... and then just take some sand paper and shape it .. but it gets a little wild sometimes useing it . but a jig saw would be fine. Austin
Old Oct 18, 2004 | 01:46 PM
scrambler123's Avatar
i used a dremel
Old Oct 18, 2004 | 02:28 PM
Yea the problem is the dremel i had broke so i need a new one. But i guess ill just try the jigsaw and maybe only take a little off at a time in case it gets messed up.
Old Oct 18, 2004 | 03:34 PM
duneaholic's Avatar
If you have a jigsaw then I would use what I had instead of buying a dremel or rotozip. JMO. Definately use a jigsaw instead of a hacksaw. Hope it comes out ok.
Old Oct 18, 2004 | 04:10 PM
tbsleeper's Avatar
the dremel takes to long..just use a jigsaw took me all of 5 minutes to cut the outline i made
