Shaving fenders
#21
Shaving fenders
Originally posted by: FoxSpirits
it looks retarted anyway, just take all the plastics off and duct tape some foam on the frame, you get the same effect, plus you can sell the plastics to someone who isnt as stupid as you and wants there quad to look good! and you make a bit of money to cover the foam and duct tape you spent[img]i/expressions/face-icon-small-tongue.gif[/img]
#22
Shaving fenders
DGpolaris2346 I like what I can see, do you have any side angle pictures? I cut mine similiar, I used a saw zaw.
I just thought about it but on trucks before with plastic valances, I have seen people use a soldiering iron with positve results. they used the rope cutting stlye of tip.
also like what you did with your floorboards, I may have to put mine back on. that way.
#23
#24
#25
Shaving fenders
Good job on the fronts DG. The reason I would cut the back is they tend to flop around too much. You shouldn't have too much trouble doing the rear seeing how well you did the front. Looks nice.
Edit: I might not cut the back seeing now that you ride a lot of mud. You might get some thrown in your face from the front. Hope not though.
#28
#30
Shaving fenders
thanks for the angled pic.
now clean the plastic particles off your front tire. lol j/k man.
for anyone else if your fenders come out alittle choppy, use a sanding block or file (something that wont fall into an indent) to fix it. if you try sandpaper it will just sand into the indent you will be trying to get rid of.
