400ex advanced timing key
Old Aug 31, 2000 | 10:48 AM
letsride400ex's Avatar
I just ordered the advanced timing key from curtis sparks and was wondering about performance and installation. Does anybody have this installed and what was the outcome, Is the installation easy or hard, will I need an impact wrench to remove the flywheel nut. thanks guys
Old Aug 31, 2000 | 01:48 PM
Skunky's Avatar
This was discussed int the "flywheel on 400ex" but no one had an answer and I finally got mine on last night. I cannot tell you about performance yet because i do not have the seals yet from honda... So lets start...
1st DO NOT START THIS PROJECT UNTIL YOU HAVE OBTAINED NEW SEALS FOR THE FLYWHEEL COVER AND IGNITION COVER. Most places need to order it since no one has pulled off the flywheel.. $12
2nd The install... Remove all the bolts around the flywheel cover and ignition cover, you may need a breaker bar (I say ignition cover because when you put the thing back togther you need to get the gear lined up) and the 1 nut on the flywheel cover.
3rd Now tap the ignition cover on the top and one side with a rubber mallet GENTLY but FIRMLY until it pops and remove ignition cover and the gear and 2 spacers.. Set aside in clean area.. Tap flywheel cover on the top and left side with the rubber mallet GENTLY but FIRMLY until you hear it make a hollow sound and the seal breaks. Remove flywheel cover gently in one straight pull out.. Remember the ignition cover will also pull off with the flywheel cover.. (The left side will feel like it is grabing but that is from the magnet on the flywheel)
4th Take an 1 1/2" cresent wrench and close it on the notch behind the flywheel bolt. Take either an impact wrench or a long enough breaker bar (1 1/2' to 2' long) and use a 17mm socket to remove the flywheel bolt NORMAL THREAD so to the left. (I used my nerf bars to hold the cresent wrench down and used my 2 foot long torque wrench to pull it off. It came off easy)
5th Take the fly wheel puller that Curtis Sparks Racing sent with the ignition key (That big bolt they sent along) and screw it into the same spot that the fly wheel bolt was until it stops. Take a ball bine hammer and screw the screw in tighter and tap the head of the bolt.. keep tightening and tapping tap it hard.. The fly wheel will pop off.
6th Remove old key and install new ignition key per sparks racing instructions.
7th Take razor blade and remove excess seal from casing taking care not to get any of the paper in the bottom end.. Intall new gasket and install fly wheel cover.,. all done
Old Aug 31, 2000 | 05:30 PM
conway400's Avatar
Ignition cover? You talking about the starter?
Let us know how you feel it changed your performance. I will do the same. Gonna try it this weekend if I can get new seals. Thanks.
Old Aug 31, 2000 | 06:14 PM
Skunky's Avatar
yaya starter cover i mean...
Old Sep 2, 2000 | 12:55 PM
SUP440's Avatar
You can purchase a flywheel removal tool for twelve dollars . Please do not risk damage to your flywheel.
Old Sep 2, 2000 | 01:20 PM
c400ex1234's Avatar
On curtis sparks website they say that it inclides a flywheel puller.... is this true?
Old Sep 2, 2000 | 05:31 PM
Motorhead's Avatar
Skunky's post says the kit comes with a flywheel puller, if you read through it all the way (some good info there).
Old Sep 2, 2000 | 06:18 PM
HRC4EVER's Avatar
7 degree advance?be prepared to use race gas or atleast a 50/50 mix with high octane fuel.keep an ear out for pinging(pre-ignition)-pistons don't like it for very long
Old Sep 4, 2000 | 11:52 PM
conway400's Avatar
Curtis Sparks says 6 degrees. And yes, the $15 includes key and flywheel puller bolt. Shipping not included. You even get a sticker.
Old Sep 7, 2000 | 05:33 AM
Fixxxer78's Avatar
What octane do you need to run with the 6 degree advance? I want to do this mod but would like to know if I’m going to need to mix fuel. Also how much increase in HP should be expected?
