1986 250R - 350 or 330 Stroker???
Old Oct 25, 2004 | 04:32 PM
ghawkman's Avatar
Default 1986 250R - 350 or 330 Stroker???
I want ESR to build my motor asap. I am not sure which one to go with. He said the 330 Stroker would be better than the 350 not stroked. I don't know the difference. Also should I get the Powervalve? It is $600 more???
I mostly dune in Glamis. If I get MID to TOP END is the bottom end completely worthless? I like to race up hills as well as dunin...??
Thanks so much for all your input and advice!!!!
Old Oct 25, 2004 | 04:39 PM
whitebroskfx440's Avatar
get teh 330 stroker and get the powervalve
Old Oct 25, 2004 | 05:01 PM
HA2's Avatar
HA2
ESR is on back order for the 310's and 330's right now.
330 stroker would be faster im sure, why not just get a 370 and get it over with. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Oct 25, 2004 | 05:09 PM
ghawkman's Avatar
They didn't offer me the 370. What all is involved in getting that motor? Is it reliable?? Will it cost a lot more than the 350??
Old Oct 25, 2004 | 06:11 PM
HA2's Avatar
HA2
cost shouldnt be much off except im sure they'll want you to get clutch on top of a 4millimeter stroker crank and rod.
its basically the 350 big bore (in stock) but with the some stroke baby.
Old Oct 26, 2004 | 02:46 AM
trapperb1's Avatar
It's explained here at ESR's website.
http://www.esr250.com/default.asp?CategoryID=16
Your center cases need to be machined to accept the stroker crank. Your center cases will also need to be machined to accept the 350 cylinder.
The 370 is the way to go for max power.
Old Oct 26, 2004 | 02:52 AM
ghawkman's Avatar
Will there be a noticeable difference between the 350 & 370?
Does the 370 have heat problems? Is the powervalve necessary? What size carb should I use and what type of fuel do I use??
Thanks!!
Old Oct 26, 2004 | 05:23 PM
DaBeechMan's Avatar
a stroked 330 is basically a 350.
Type of fuel depends on how you want the motor setup as
Powervalve is only needed if you do a lot of low to midrange riding since the valve is typically setup to open at 5k-6000 rpm with peak power around 9500
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Sep 1, 2015 11:59 PM
