ac 650 vs bf750 vs grizzly660 (all 05 models)
Old Oct 26, 2004 | 10:01 PM
millsd's Avatar
Default ac 650 vs bf750 vs grizzly660 (all 05 models)
Planning to buy a utility atv this weekend. Done quite a bit of searching and still conflicted. I like the mrp, look, and feel (minus the footbrake) of the 05 AC650. The grizz was pretty nice as well, but doesn't seem as strong. BF felt a bit tippy and probably unecessary power.
That said, I'm looking for a machine that will push some serious snow with some mountain climbing in the summer. I live in MA with a 300 yard driveway and own 90 acres in VT. Seems that the 700lbs and v2 of the ac would do good...but maybe the grizz?...hmmm...then there's that bf750. Just hoping to make a good decision. Definitely like the Yamaha dealer best.
Any thoughts? Also, seems that the moose 60" tapered plow is the best, but would like more feedback on that as well.
thanks.
Old Oct 26, 2004 | 10:46 PM
ridinhigh's Avatar
Yeah you will need weight. I'd say the AC or even a Polaris. I have a Grizz with a plow and it does alright but you need to add some weight on the back end. The BF has too much power and not enough weight, more of a fun wheeler than for work.
Old Oct 26, 2004 | 10:52 PM
2phast4u2catch's Avatar
i would deff sat ac cuz polaris r not the reliable and not many dealers offer parts fer polaris also u could get the bf or griss and just put a couple sand baks on the rear rack i dont really no much abotu the ac but it sounds good
Old Oct 26, 2004 | 11:11 PM
longbox's Avatar
I agree that for plowing, it would be easy to just add weight to the racks as needed. This might be a better option since when out riding for fun, you would have a lighter quad. Any of these choices will have enough power to push a plow without any problems. Depending on how much maintenance/repair you can do yourself, having a good dealer can be a very important consideration when choosing a machine. Keep in mind that most people are brand loyal, and will usually tell you that the machine that they own is the best for everything.
Good luck!
Old Oct 27, 2004 | 12:04 AM
batmanacw's Avatar
If you want to climb hills then I would go with the Grizzly. It is very powerful and will climb almost anything without effort. It is light and agile on the trails and a real blast to ride. It is very easy to add some weight to plow, but why would you want to carry it all the time. I don't like the stock griz tires and it is its only weak spot. I have no complaints about its power and stability. The low gear is plenty for plowing and general towing.
Old Oct 27, 2004 | 02:24 AM
Andy Bassham's Avatar
The first guy had a good point. If you are into some serious plowing, the weight would make a difference. The AC and Polaris both are heavyweights, and if you wanted to go a step further, Bombardier makes a fat *** quad too. And of course they all have plenty of power.
you won't get a 650 and not have enough power. You might get one that will outrun another one, but you won't be underpowered with anybody's offering.
Old Oct 27, 2004 | 10:20 AM
millsd's Avatar
Andy,
I noticed your pics have both AC and the Grizz. Do you own them both? Do you like one over the other? Any key differences? I know the year and models don't really line up, but I'm guessing you have some definite opinions...
thanks.
Old Oct 27, 2004 | 11:03 PM
batmanacw's Avatar
Again, the weight is not important because, unless you are disabled, you can put a $5 bag of concrete on the front and back. Buy one that will perform on the trails and anyone of them will do the plowing.
Old Oct 27, 2004 | 11:50 PM
ridinhigh's Avatar
Because most of the lightweights are not designed to handle 100-150extra pounds on the front or rear racks. Do that and try turning with a blade up or manuevering a trailer. It Sucks.
Old Oct 28, 2004 | 02:10 PM
batmanacw's Avatar
Whatever, dude!
