Pred Steering
Old Oct 27, 2004 | 08:11 PM
Lugnut03's Avatar
Default Pred Steering
Has anyone had problems with your steering becoming extremely loose? I have a 2003 Pred and have replaced the tie-rod ends, but seem to have a lot of movement in the steering block/mount as well as the center links...are their after market kits available...HPD no longer manufactures their kit...
Old Oct 27, 2004 | 08:19 PM
Bradracer18's Avatar
Is it your steering post bushings?? If not, I can't think what it would be.........you might try getting on predatorowners.com and asking too. It is a good steering system, so it should be something simple.
Old Oct 27, 2004 | 08:27 PM
Lugnut03's Avatar
The upper steering bushing is junk, but I can actually see movement in the steering block mount and the center links....I will check out predator owners.com .....thanks!
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
BYC
Sep 25, 2015 02:10 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Logan Collins
Sep 5, 2015 08:03 PM
