1983 HONDA 200 MOTOR SWAP TO 1984 200X
Old Oct 30, 2004 | 01:35 PM
DINGERS1's Avatar
Default 1983 HONDA 200 MOTOR SWAP TO 1984 200X
I HAVE A 1983 200 ATC THAT RUNS GREAT. I HAVE THE CHANCE NOW TO PURCHASE A 1984 200X THAT HAS A BAD MOTOR BUT IN GOOD SHAPE. IS MY MOTOR IN THE 200 ATC ABLE TO FIT IN THE 200X FRAME? THANKS FOR YOUR HELP
Old Nov 1, 2004 | 02:29 AM
KNOWSALOT's Avatar
The Facility
DINGERS1,
It is a direct bolt in swap regarding the engine mounting.
However, you will need the intake manifold from the 200X engine to keep the carb lined up with the airbox intake boot and you will need to make a bracket for the footpeg on the right side.
One more thing, most people who do these swaps end up lengthening the fottpeg on the left side because the recoil starter assembly takes up so much foot space.
Because of that, and the right side bracket situation......I would just go and make a new set of matching pegs that mount in a location suitable for your riding style.
Good luck.
Old Nov 1, 2004 | 10:19 PM
DINGERS1's Avatar
why do you have to change the right footpeg? what exhaust do i use?
Old Nov 2, 2004 | 10:07 PM
Wes350x's Avatar
Hey knows, aint saw ya in a while. How ya been?
Old Nov 3, 2004 | 04:09 AM
rob0781's Avatar
we had problems with the left side footpeg when we did a swap,the shaft for the shifter was to long and we couldn't bolt the peg up...we handled it the wrong way now that i think about it ,rather then building a bracket to mount the peg too,we took the shifter off the shaft cut the shaft down about an inch then welded the shifer to the shaft........it's been working great but we should have done it the proper way,doesn't matter now cause were swapping bottomn ends that one is stripped where the front sprocket shaft,so were better off to use another bottom end.
Old Nov 3, 2004 | 11:42 AM
DINGERS1's Avatar
how did you handle the rear brake pedal mounting? did you use the 200x exhaust?
Old Nov 3, 2004 | 03:44 PM
rob0781's Avatar
there is no rear brake on it yet,as for the exhaust it's just a cobra muffler and header it's made for 185/200cc honda trikes,it fit no problem..
Old Nov 3, 2004 | 05:50 PM
DINGERS1's Avatar
I TRIED THE STOCK EXHAUST FROM MY 1983 200 ATC THAT WONT FIT BECAUSE IT COMES OUT THE REAR IN THE MIDDLE OF THE BIKE. THE 200X COMES OUT TO THE RIGHT SIDE. I DONT HAVE THE 200X EXHAUST SO MAYBE I'LL LOOK ON EBAY. ANY IDEAS ON THE REAR BRAKES?
Old Nov 4, 2004 | 09:58 AM
LocknLoad's Avatar
I did a similar swap, except I used a 1981 185s engine. The stock 200x exhaust bolted right up to the 185 engine. I think your 200 is simply a bored out 185 so it should bolt up also. I used the 200x carb and manifold, they also bolted right up. I didnt change anything on the rear brake, still used the stock brake peddle.
Jul 22, 2015 05:00 AM
CRamshaw777
Jul 18, 2015 05:46 PM
ghost civic
Jul 15, 2015 10:48 PM
timster911
Jul 13, 2015 01:57 PM
