blaster central?
It's very case sensitive. Not like it matters right now. The servers are down to be moved and nobody can get to it until they arrive at the new location.
On top of that, I made a sort of large update. Members get first wack at it, so the Guest pass won't be valid for a bit.
YFS200
YFS200
Yea, I prefer the twist throttle myself. I rode dirtbikes, and still do so that may be the cause. But yea, your blaster is very tricked out. I'm planning on getting one very soon. What do you think the best pipe/silencer combo is? And also the best shocks for jumping. Thanks.
I love it, it sounds great and is much better than stock. i should probably be at a 250, or 260 but im only at a 240 main jet. after i rejetted i noticed a lot more bottom end, then with a 230 main jet, it still could use a little bit more in 4,5,6 but if i put a 250 in it, that would probably make the difference
