Please help with my 250x
Old Nov 1, 2004 | 05:41 PM
250what's Avatar
Default Please help with my 250x
Whats up everyone. I just bought a 1987 250x. I am new to the ATV world and need a little help well here we go. The ignition switch will not turn so I can't get it started. If you wiggle the switch and hold it as far as you can to the on position you can get it started but as soon as you let go of the switch it cuts off. I have tried hooking up a toggle switch and that isn't working. I need to try and get it running so I can see what I need for it. Does anyone have any advise that might help?
Old Nov 1, 2004 | 09:30 PM
TractorPacker's Avatar
Do you have a balloon?
If the problem is the key, you can by-pass it. Unplug the 2 wires of the key. Plug the 2 wires that are on the quad together,hot wired no key needed.
Old Nov 1, 2004 | 09:36 PM
250what's Avatar
I tried that and it still will not start. Do you think it could also be something else if so do you have any sugestions? Like I said I have had it running with messing with the ignition switch. I should be trying to start it with the choke open right?
Old Nov 1, 2004 | 09:54 PM
Pull out the spark plug, plug it into the wire, then ground the plug. Kick it over and seeif it sparks. Mess with the wires and see if it quits sparking during this. If you kick it and doesn't spark moves wires till you find the bad spot.
It could also be in the kill switch, but that will be hard to test.
Old Nov 1, 2004 | 10:04 PM
250what's Avatar
Cool I will try that tomarrow. I will let you know if that works.
Old Nov 1, 2004 | 10:05 PM
250what's Avatar
Also where is the kill switch and how hard is it to replace?
Old Nov 3, 2004 | 05:52 AM
Mutha's Avatar
Perhaps you have a wire that is grounding out on the frame/handlebars somewhere?
Try kicking it over/starting it in a dark environment. Sometimes you can see a spark and can tell where it is grounding out using this method.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 3, 2004 | 06:33 AM
DaBeechMan's Avatar
so messing with the ignition switch will fire the motor, but bypassing the ignition switch doesnt work? That doesnt make sense
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
