Cleaning ATV
Old Nov 1, 2004 | 06:56 PM
REALSORRY's Avatar
Default Cleaning ATV
Hi, I have a 2001 polaris trailboss (I doubt that matters) and I have always wondered if it is ok to spray the ENTIRE ATV with soap and water? In the past I have just tried to avoid all of the switches on the dash, and the engine. Would it be ok to spray everywhere I can get with soap and water?
Jeff
Old Nov 1, 2004 | 09:28 PM
highwayman's Avatar
I usually spray my bike all over except the speedo because it sometimes fogs up. But on the other hand I have driven my bike in the pouring rain and it hasn't hurt any thing. I have also have had the buttons and switches freeze up when I've washed in the winter. So in general I wash every thing in the summer and am more carefull in the winter
Old Nov 1, 2004 | 09:40 PM
silverbullet2005's Avatar
when I wash the wife and I's quads I scrub the whole quad down with soap and water then rinse. I have even went as far as to take the composite luggage racks off to wash under them and get all the dirt stains off. I still haven't figured out what to use to get the engine area shining, cause you can't reach it with a wash mit or brush. is there something to spray on it to get it clean, maybe engine degreaser/cleaner?
Old Nov 1, 2004 | 09:47 PM
Polaris500HO4x4's Avatar
take off the side plastics just give it a yank and they pop out. its lots easier to reach in there then
Old Nov 1, 2004 | 09:53 PM
wagntwister's Avatar
I have had my 04 500 ho down to the frame and I mean just frame and motor all racks and plastic removed and power washed it put it all back together and had zero problems. Just use common sense around the swiches and electrical stuff
Old Nov 1, 2004 | 11:33 PM
REALSORRY's Avatar
ok, awsome guys, thanks. I just wanted to make sure it was ok to spray everything.
Thanks,
Jeff
Old Nov 2, 2004 | 01:03 AM
BigBadScrambler's Avatar
SIMPLE GREEN......SIMPLE GREEN.........SIMPLE GREEN........................... The stuff is a gift from god!!![img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
You will be fine with spraying everything. These machines are built to be waterproof.
Old Nov 2, 2004 | 05:04 AM
jimmypsp700's Avatar
Be careful with a pressure washer around the instrument panel and the zerks. The manuals says to grease afterwards and probably wouldn't hurt to ride it a little after to displace the water in the fittings.
Old Nov 2, 2004 | 07:00 AM
ozarkmaster's Avatar
What i do it i use car wash and i pressure wash it then when im done i take black magic tire foam and spray all over the plastics and the seat. wipe it off 10 min. later but make sure you spray the tires so you get that nice show quaulity look,[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 2, 2004 | 08:18 AM
biohaZ's Avatar
be carefull with the pressure wash, dont spray it at anything that looks like it can fall apart
