Does your Kodiak move forward in H?
Old Nov 6, 2004 | 11:42 AM
DougMd's Avatar
Default Does your Kodiak move forward in H?
When I put mine in H, it doesn't move forward unless I give it gas, unlike a car that moves in D even without pressing on the gas pedal. I was in grass when I did it with my Kodiak yesterday, but wonder if that is normal. I realize it has engine braking, but just want to be sure.
Old Nov 6, 2004 | 12:10 PM
TrailBlazerguy250's Avatar
o yeah thats normal , i cant get mine into low though ? can any1 help plz
Old Nov 6, 2004 | 12:25 PM
zsebi's Avatar
yes, normal.
most ATVs have a centrifugal type clutch which is actuated by raising the engine RPM, at idle speed the ATV should not move regardles which gear is it in. (unless you are on the down hill [img]i/expressions/face-icon-small-smile.gif[/img] )
on some ATVs ( example kodiak) this allows you to start the ATV in any gear, by simply applying the rear brake as a safety meassure.
automatic transmission in cars use torque converter clutch which is mainly operated by hyraulic fluid or lets call it trans fluid. it slips when you take off , than a computer contorled solonoid locks it it up solid once you are cruising.
it is a totally different animal.
Old Nov 6, 2004 | 01:10 PM
1ShotScott's Avatar
you want to have that on an atv because if you get off it while it's in gear you don't want it rolling away from you.
Old Nov 6, 2004 | 02:30 PM
anyone know why my kodiak wont go into low ?
Old Nov 6, 2004 | 03:04 PM
hondabuster's Avatar
To get mine into low, i usually have to do the honda rock. rock the quad front to back, and make the wheels turn a bit. The cogs in the tranny arent quite lined up, and they need a bit of movement to line them up.
If this doesnt do it, then the shift linkage probably needs to be adjusted.
Does the low light come on?
Old Nov 6, 2004 | 03:09 PM
but i have to put the brakes on to shift so it wont roll the wheels, doesnt have a low light
Old Nov 6, 2004 | 03:11 PM
1ShotScott's Avatar
well may be thats a saftey feature like how you have to pull in the brake and hole the boton on the rancher.
Old Nov 6, 2004 | 03:13 PM
doesnt have a button , its on the shifter , ill beable to check it out tommrow
Old Nov 6, 2004 | 03:18 PM
thank yall for replyin
