chain and sprocket question.
Old Nov 7, 2004 | 01:31 AM
rob0781's Avatar
Default chain and sprocket question.
ok i know all should be changed together but my chain is still good and my front spocket is still good,but i my rear sprocket is warped can i get away with changing just the rear...be a waste to change a fairly new chain and front sprocket.
Old Nov 7, 2004 | 04:16 AM
maddog56's Avatar
If your front sprocket and chain are in good shape, you can get away with just changing the rear. If you have a lot of ride time on the other components, I would look into changing them though as well. As cheap as front sprockets are, I would change that anyway, and then decide if the chain is worth changing.
Old Nov 8, 2004 | 02:47 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
An aluninum rear sprocket will quickly wear to fit a chain, even if it is a little stretched. I buy a new chain, front sprocket, and two rear sprockets. And, I figure on changing the rear sprocket out once during the life of the chain.
buddieboy
Dec 9, 2016 05:50 PM
mrtidy
Feb 3, 2016 05:00 PM
bigred20653
Oct 2, 2015 10:05 AM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
