Mojave questions
Old Nov 8, 2004 | 12:24 AM
jfisher304's Avatar
Default Mojave questions
I am trying to revive an old Mojave and need a couple of questions answered. In the lighting harness up front, there are four or five wires where the front light and key switch attach. The hood was missing when I got this heap, so I need to know which two wires go to the key switch, and also whether they need to be wired toogether or left apart for it to run with no key. I think I remember reading that a teather switch for a Mojave is normally closed so I assume I need to tie the wires together, but I just wanted to be sure. Also, is there a choke **** that can be attached to the carb directly so I can get rid of the handle bar mounted choke handle? I have pulled the parking brake assembly off and would like to be able to switch to a MX style clutch perch instead of that bulky stocker.
Thanks
Jason
Old Nov 8, 2004 | 12:29 AM
Chris142's Avatar
I dunno the wire colors but to make it run w/o the key you need to leave the wires unplugged. The key is a switch to ground and leaving them unplugged is like having the key "On".
Old Nov 8, 2004 | 12:32 AM
jfisher304's Avatar
Ok, thanks for the info. I'll just seal the connectors up and tuck it all up out of the way.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
