Rough crank bearings
Old Nov 10, 2004 | 11:45 PM
yamahatheonlyway's Avatar
Default Rough crank bearings
I have had my motor apart for a few weeks on my 250r and i went to spin the crank the yesterday and i noticed it was really rough.... and there was rust collectin on the crank itself.... im from wisconsin... and its really humid up here, so i think thats the culprit.... now, my question is.... what now? I am wonderin how difficult it would be to split the halves, without the tranny fallin apart.... Also.... i think the connectin rod bearing is rough too..... how do i replace that one? I just need somebody that knows what they are doin with bottom ends and stuff... cuz i am good with mechanics.... and i dont want to have to take it to some guy that will harge a bundle for labor.... i just need to know what to do... and what not to do.... in splittin the halves
Old Nov 11, 2004 | 01:02 AM
pendejo's Avatar
Well, to solve all the mentioned problems and not have to worry about it, buy a new crank since they already have rods pressed on. Also get new main bearing and seals. Now, to split the cases, this is a biiiiiatch. I'm doing the same on my R motor. Well actually, it's not that bad if you have a clymer. You should be able to take one half off without the tranny coming out. It is recommended that you use a case splitter, however all I did (after removing top-end) was LIGHTLY tap on the cylinder base studs with a 2x4 and a hammer. Hope that answers your questions.
Divergent12
Dec 30, 2017 08:33 PM
SOLOLUCKY
Oct 24, 2016 03:36 AM
robert301972robert
Aug 30, 2015 11:34 AM
clsharky
Jul 13, 2015 02:07 PM
