Assembling the motor.
Old Nov 12, 2004 | 06:23 PM
Troyer23J's Avatar
Default Assembling the motor.
Should I put the whole motor together, then put it in the bike? Its hard to get in there i know. Or, should i bolt in the bottom end, then the cylinder, then the head?
I havent done this before.
Thanks guys.
Old Nov 12, 2004 | 06:55 PM
CED's Avatar
CED
Put the whole motor together,that way you can torque everything good.That's the way i do it anyway.
Bubba297's Avatar
It is very much so easier to assemble the motor on a table or something similar then put it in the bike. You can reach everything from all angles and torquing the base bolts are easier as well.
Old Nov 12, 2004 | 06:57 PM
Troyer23J's Avatar
Ok.
With the gaskets for the motor, do you put anything on them, or just them?
Old Nov 12, 2004 | 07:30 PM
Bubba297's Avatar
Dont add anything to the head or base gasket. If your using the OEM base gasket then make sure the white "putty" is installed up towards the cylinder. Also on the head gasket dont get it upside down, it is very easy to do. There should be a small tab that will line up with the cylinder on the exhaust side if it's on correctly. Just making sure everything is clean and oil free is the important thing.
Old Nov 12, 2004 | 08:33 PM
Troyer23J's Avatar
Does the needle bearing get any grease or anything?
Old Nov 12, 2004 | 08:35 PM
Troyer23J's Avatar
The wrist pin bearing I mean.
Old Nov 12, 2004 | 09:00 PM
Troyer23J's Avatar
Ok. I got the cylinder on.
Put the wiseco on the rod, arrow pointing to the exhaust port. Then the gasket. Then the cylinder, witht he rings centered on the little pegs in the ring grooves.
Everything ok so far?
Old Nov 12, 2004 | 11:23 PM
Bubba297's Avatar
sounds like your doing great so far[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 13, 2004 | 12:48 AM
Troyer23J's Avatar
The motor is all together and Torqued. Had to ruin a wrech and socket to make a tool to torque the base bolts down with though. But now I have one.
Everything went pretty well. Those damn cir clips are hard to get in the piston though. Tomorrow the motor goes in the bike. By wednesday i should have the rest of the stuff i need and should be running shortly there after.
I cant wait.
