Drive and driven clutch shims, Dealer no help
Well today I went to the dealer to order some adjusting shims for the driven clutch, and some spring shims for the drive clutch. I must have been speaking French, because they had no Idea what I was talking about. I looked at the Microfish, and I couldn't see them either. Does anyone know the part #'s for these items so I can order them? Or maybe somewhere online I can order them both?
Thanks Hitman. I just tried again and that site just doesn't work for me. I go through all the steps like picking the CC's, model, year, etc., and then it takes me to the screen that says "Please select a component from the list on the left" I then chose the converter/clutch item and it sendsme to a screen that says my shopping cart is empty. Isn't it supposed to send you to a diagram of the converter? I am I doing something wrong? I need to order these parts!! Thanks for the help............Ernie
CF&W here you go.
for the driven clutch pn#
92026-0034 spacer T=0.30
92026-1569 spacer T=0.60
92026-1617 spacer T=0.80
92026-1565 spacer T=1.00
92026-1570 spacer T=1.40
i used the pn# from the v-force which gives you an extra shim number, they are all the same after that. the prairies dont list the 0.30 shim which i have used on mine to get that extra little bit of adjustment.
for the drive clutch pn#
92026-1603.
i think this is the one you want, where as i havent tryed to order this shim for mine. if you have the 650p try the 700p spring, thats what i have in mine and i like it. JMO.
92026-1603.
Thanks, Deerchopper, for the part #'s! I knew someone had them out there. I glad it's not just me having problems with the Kawi site. [img]i/expressions/face-icon-small-confused.gif[/img]
