05 Sportsman 400 question
Old Nov 14, 2004 | 02:21 PM
05sportsman400's Avatar
Default 05 Sportsman 400 question
hey everyone, im new to the forums here. i just purchased an 04 Sportsman 400 and was wondering what kind of RPM's you are all having to get to until the machine starts to move. When mine is in high gear, it takes like 2500 to get it moving. does this number sound right to you? when its in low gear alot less rpms are needed.
Old Nov 14, 2004 | 03:17 PM
Tarball's Avatar
All I can tell you is that mine idles at 1450......and must go higher than that to move. Dealers and friends stress not using
High unless on the level or moving about 10 mph or better. Then, they stress it some more.
Old Nov 14, 2004 | 10:50 PM
Kushman's Avatar
Sounds about what stock is.......what you need is a "heelclicker" clutch can be adjusted to what you need.....mine engages at 1500, just whree i want it
Old Nov 15, 2004 | 01:23 AM
Polaris500HO4x4's Avatar
mine will engage at around 2000 and less the quicker you apply the throttle.. this PVT is dependant on engine speed and tourq requirements. as the engine speed increases the force exerted on the movable drive shaft sheave by the flyweights also increases. this will increase the "pinch" applyed to your belt for quicker engagements.. in other words the quicker you apply yur throttle the quicker your clutch will grab the belt
Cole Hadden
Jun 15, 2025 09:05 AM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
toonces
Jul 11, 2015 12:01 PM
200es
Jul 10, 2015 09:09 AM
