holeshot module
Old Nov 15, 2004 | 10:21 PM
HughJazz's Avatar
Default holeshot module
Will a holeshot module for a 650 praire fit a brute force. will it make much difference
Old Nov 15, 2004 | 10:48 PM
Jeffro31's Avatar
They will fit but I did not install mine on my BF , I sold it with my prairie , I bought a ICM power pack from highlifter , it is WAAAY better then the holeshot module , since the holeshot only works under 5mph and cuts off at around 35 or so it is basicly useless in the real world although it was fine doing drag racing as long as you was sitting still but more times that not I would be rolling along fairly slow and somebody was gas there and away we would go , that when the holeshot is worthless , get a ICM , super value , great price.
Old Nov 19, 2004 | 01:37 PM
BLOWNBF's Avatar
I PUT THE HIGHLIFTER MODULE ON MY BF AND ILL TELL YA IT HAS MOR LOW POWER THAN IT EVER HAD BEST 100 BUCKS IVE EVER SPENT IT IS A WHELLIE MACHINE IT PULLS MUCH STRONGER NOW ALL THE WAY TO TOP SPEED ALTHOUGH NO DIFFERENCE OF TOP END 67MPH BUT MUCH QUICKER
Old Nov 19, 2004 | 02:17 PM
NewBF750rider's Avatar
I just went through this stuff because of my new brute and I can't beleive the difference the dg5 makes on the brute. I gained from 56 to 62mph where I run out of room. I picked this one cause it was cheap and was only one that was made different for the brute. Most other using same thing. I think the holeshot was made by dg5 people long ago. They said dg5 replaced dg3 to. I like the built in switch that turns it off without having to wire some other switch in there. You won;t beleive what 7+ more hp will feel like until you try it. just call 714-299-3865 and ask if they will send you some more HP for the brute!
MikeyBoyesq
Nov 27, 2020 02:44 PM
STLyamwar
Jul 25, 2020 04:44 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
