oil and coolant questions
alright i've done some research on what oil and coolant to use for my ds but i wanted some last opinions from you guys before i did anything so here are my choices. tell me what you would do or do.
amsoil 10/40 $5.95
0/40 $8
Bel Ray 10/40 $3.99
redline 10/40 $7.95
mobil 1 10/40ms4t $8
Coolant:
Prestone (if u favor this what kind of preston they have a bunch of choices at the stores)
coolanol
engine ice
thanks a lot for your help guys!
amsoil 10/40 $5.95
0/40 $8
Bel Ray 10/40 $3.99
redline 10/40 $7.95
Coolant:
coolanol
engine ice
Shell ROTELLA® T Synthetic 5W-40 $3.25 qt. or 12.95 gallon
I used to use Mobil 1, but they changed there chemistry and clutch started to slip.
I have been using this oil the last year and have taken the motor apart to change shifter forks and everything looked great.
I have the 40 % springs and no clutch slipping.
Antifreeze should be used to match the temperatures that you live in.
If you only need protection to 30 degrees, dilute to the temp.
The higher the concentration the more heat it will hold.
Heat hurts engine life and horsepower.
1ArmBandit
55
Oct 14, 2015 09:03 PM
