oil and coolant questions
Old Nov 16, 2004 | 12:03 AM
dabomb03's Avatar
Default oil and coolant questions
alright i've done some research on what oil and coolant to use for my ds but i wanted some last opinions from you guys before i did anything so here are my choices. tell me what you would do or do.
amsoil 10/40 $5.95
0/40 $8
Bel Ray 10/40 $3.99
redline 10/40 $7.95
mobil 1 10/40ms4t $8
Coolant:
Prestone (if u favor this what kind of preston they have a bunch of choices at the stores)
coolanol
engine ice
thanks a lot for your help guys!
Old Nov 16, 2004 | 07:32 PM
dabomb03's Avatar
doesn't someone want to voice there thoughts?
Old Nov 16, 2004 | 08:29 PM
Oldmanracing's Avatar
Shell ROTELLA® T Synthetic 5W-40 $3.25 qt. or 12.95 gallon
I used to use Mobil 1, but they changed there chemistry and clutch started to slip.
I have been using this oil the last year and have taken the motor apart to change shifter forks and everything looked great.
I have the 40 % springs and no clutch slipping.
Antifreeze should be used to match the temperatures that you live in.
If you only need protection to 30 degrees, dilute to the temp.
The higher the concentration the more heat it will hold.
Heat hurts engine life and horsepower.
Old Nov 16, 2004 | 08:34 PM
Eaglecollector's Avatar
Honda HP4 no Molly
Engine Ice
Old Nov 16, 2004 | 11:01 PM
dabomb03's Avatar
is the honda hp4 synthetic?
Old Nov 17, 2004 | 08:48 PM
It is a Synthetic / Petroleum blend
Edit:
forgot to add aprox..$6.99 a quart.
shimanok2
Jan 29, 2016 07:37 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
