Putting Front blade meant for SP500 on SP700
Old Nov 16, 2004 | 10:56 AM
VetteVert's Avatar
Default Putting Front blade meant for SP500 on SP700
I have a Sportsman 700, and can get a great deal on a front blade, but it was meant for a sportsman 500. It is a Polaris brand blade. Does anyone know if it will fit the 700, and what modifications would be necessary?
TIA
VV
Old Nov 16, 2004 | 11:14 AM
Raistlin's Avatar
I don't think you'd have to make any modifications. I think they have the same chassis, just different engines. The polaris plow's aren't model specific, so I'd think aftermarket would be the same.
Old Nov 16, 2004 | 11:33 AM
VetteVert's Avatar
I think it is the attachment and lift kits that are model specific. I assume the mounting plate is different. I just need to know if it will work on a 700...
Thanks!
VV
Old Nov 16, 2004 | 11:52 AM
Raistlin's Avatar
http://www.purepolaris.com/Detail.aspx?ItemID=2871732(PolarisPGACatalog)&Depa rtment=ATV(PolarisPGACatalog)&Category=ATVAccessor ies(PolarisPGACatalog)&Listing=ATVPlow(PolarisPGAC atalog)
This is a link to Polaris' website, shows a universal plow kit. Looks like it uses the same mounting bracket regardless of model. So, if you are buying just the blade? not sure. It looks to me like the aftermarket stuff seems to work like that.
Hope this helps.
Old Nov 16, 2004 | 12:17 PM
silverbullet2005's Avatar
the plow itself should fit but the lift mounting will be different.
Old Nov 16, 2004 | 12:38 PM
VetteVert's Avatar
I'm buying the whole mess...so I need to know if the mount bracket will work on a 700
Old Nov 16, 2004 | 01:08 PM
Raistlin's Avatar
Silverbullet is correct, after further review of the Polaris website, the mounting kits for the 600/700/800 are different from the 400/500/ATP. It would appear that you need to look at seperate mounting hardware.
How great is the deal?
You might be spending more frustration than saving money getting it to work. I'd talk to your dealer, and see what he can offer in the line of mounting kits for the blade.
I paid 69 for the mounting bracket
219 for the glacier kit, and 299 for the five way 54" VPlow. All in all about 600 bucks.
With that said, if you can buy just the blade cheap, order the correct mounting gear.
Old Nov 16, 2004 | 01:46 PM
VetteVert's Avatar
$150 for the blade, arms, and mounting kit. New, of course.
$69 for the mounting bracket is much better than the advertised $139 on their site....
Old Nov 16, 2004 | 02:11 PM
Raistlin's Avatar
That 69 is the bracket for the glacier system, basically a square piece of steel with a v in it..... I think the mounting brackets for the manual lift systems is more money, because of it's size.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
txkevin
Sep 21, 2015 02:02 PM
scaldwellk
Jun 19, 2015 05:08 PM
