650 keeps dying
Old Nov 16, 2004 | 08:55 PM
2BIG2BFAST's Avatar
Default 650 keeps dying
The bike will start and you can ride it for about 10 to15 minutes then it will die. After about a minute it will fire right back up and run great. Cleaned the carb and the tank nothing seem to be in there. Any suggestions?
Old Nov 16, 2004 | 09:01 PM
SpinCycle's Avatar
Maybe the float is sticking closed or the needle is obstructed and not flowing very much ( float bowl fills slowly then it runs until the bowl is empty ). Check the bowl drain right after it dies, see if it's empty. If not that then maybe your CDI, might try swapping back to the stock one..
Old Nov 16, 2004 | 09:18 PM
atvaddict01's Avatar
The vent line coming out of you tank might be pinched
Old Nov 16, 2004 | 10:49 PM
warriorbansheeboy's Avatar
wow that is really wierd
Old Nov 17, 2004 | 01:30 PM
Camds650's Avatar
I had the same thing happen to me and it was the vent line from the tank. If it quits again lossen the gas cap and if it starts that is the problem. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 17, 2004 | 07:25 PM
2BIG2BFAST's Avatar
I ran the DS without the gas cap on and it runs great now. i guess its just a matter of checking out the vent line from the tank. thanks for the help guys.
Old Nov 18, 2004 | 03:58 AM
2BIG2BFAST's Avatar
You were right on the money bud. The tanks air vent hose was kinked in two places. the viper runs great again. thanks again for the help.
Old Nov 18, 2004 | 02:26 PM
BOMBSAINT's Avatar
I had the same problem. the vent line design sucks. now i am in the process of machining a aluminum cap with a breather. doing it myself as oppose to paying fifty bucks.
Old Nov 18, 2004 | 07:11 PM
Thats cool when it something easy.Have fun.I had the same thing after doing
crash repairs.If it wasnt for past posts id have been lost.
Old Nov 20, 2004 | 01:19 PM
Pellter's Avatar
does it shut off when its hot?
if so i think it is your regulator
