Anyone have any results of a sound check for a pipe on a baja or any ds?
Old Nov 16, 2004 | 11:38 PM
duneittilludie's Avatar
Default Anyone have any results of a sound check for a pipe on a baja or any ds?
I am still trying to decide on a pipe for my baja and although i know i can do a search about pipes i would really like to hear from someone who has actually had a pipe sound check done .I am trying to not go above 96 decibels even though the limit is 93 where i ride.Any responses with some actual numbers would be appreciated.
Old Nov 16, 2004 | 11:50 PM
DuneRider650's Avatar
I ride a little here and there......
There isnt much below that
Old Nov 17, 2004 | 12:07 AM
JMAC650's Avatar
My FMF powercore 4 with quietcore insert db's at 93. 101 without insert.
Old Nov 17, 2004 | 12:47 AM
crackerJack's Avatar
How stubborn are they with the 93 db at the oregon dunes??
Old Nov 17, 2004 | 01:03 AM
OregonDunePatrol's Avatar
You can get away with 96 most of the time. But if you have attitude when the pull you over for not having a flag, or riding out of bounds, you'll be toast.
Old Nov 17, 2004 | 01:06 AM
how do you like your fmf powercore 4 pipe my friend has it for his 400ex and its VERY loud
Old Nov 17, 2004 | 01:31 AM
JMAC650's Avatar
It works great on the low end but falls off on the top end. I just ordered a Yosh RS3 for my DS. It is supposed to put up some good dyno numbers.
Old Nov 17, 2004 | 01:42 AM
crackerjack.As (oregondunepatrol) said you can get away with a louder pipe most of the time but if the rangers want to go by the book they can and will ticket you. I would be happy with a 96 decibel rating because you can generally get away with being 3 decibels over the limit but so far i cant find anything for the baja that is even close to that.
Old Nov 17, 2004 | 02:31 AM
busmechanic's Avatar
I saw a guy get tested on a raptor with LTE duals. he passed at 92dbs. I talked to him after he was tested. it was at winchester. and he was the only one that passed when I was there.
Old Nov 17, 2004 | 01:13 PM
BlackWidow's Avatar
Here's a link to some sound testing data
Sound testing link
Hope this helps.
