air pressure for scrambler tires.
Old Nov 17, 2004 | 02:05 PM
conig's Avatar
Default air pressure for scrambler tires.
I was purchasing rims and tires but ran into some snags with an online merchant which will probable set me back about a month. that being said, are there any tricks for increasing handling with the stock 489 tires? when I auto crossed my old svt, I used to adjust the handling of the car greatly by adjusting tire pressure, can I do this with my scrambler? I would run 2 psi more pressure in the rear tires then the front to reduce there grip to increase over stear.
what pressures do you guys run? or more importantly what difference in pressure do you guys run betwwen front and rear tires?
Old Nov 17, 2004 | 02:10 PM
omahapredator's Avatar
same as i run in my pred 4.5-5 in front and 3.5-4 in rear
Old Nov 17, 2004 | 02:18 PM
Bradracer18's Avatar
I run about 7 in the rears and about 5-6 in the fronts........
Old Nov 17, 2004 | 02:43 PM
scarabrick's Avatar
I ran the recommended tire psi on myscrambler 2005, 500 and got TWO flats when my sp 05 500 got none. I since went back to 5 and 5 and so far good to go . I think I''l try and bump it up a psi or more next time.
Old Nov 18, 2004 | 02:29 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i run about 4.5 in the rear for more traction
6lbs in the front/rear otherwise
Old Nov 18, 2004 | 02:34 PM
scarabrick's Avatar
I ran 7 psi in the rear last night and boy what a difference. I could slide the bike all over the place. The ride was rough but I think I'll try 6 psi
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
cboler9
Sep 24, 2015 08:35 PM
