Changing jets in the 39mm carb.
Old Nov 17, 2004 | 04:47 PM
Troyer23J's Avatar
Default Changing jets in the 39mm carb.
For the guys with the 39, how do you change jets? I mean, what all do you take off the bike to do this. With the regualr carb, if you moved the airbox, you could take the carb off easy, but with the 39, its so hard to get it on the intake boot that I dont want to take it off. I have the right main jets to get it tuned, but twhat about the others, and the air screw and stuff. I haven't tuned a carb before.
Old Nov 17, 2004 | 04:52 PM
omahapredator's Avatar
what kind quad? scrambler? just take off all the plastic you can then turn the carb while in the boot to get to the bowl to change the jets...ride it with the plastic off make adjustments untill right then put plastic back on...that's the easiest way good luck
Old Nov 17, 2004 | 04:58 PM
Troyer23J's Avatar
Yeah, scrambler.
Old Nov 17, 2004 | 05:04 PM
just get them front plastics off and it's whole new world!!!!
Old Nov 17, 2004 | 05:46 PM
Troyer23J's Avatar
But in order to spin it enough to get the bowl off i have to take off the inner clutch cover, which means the clutches. It won't spin the other way b/c of the tranny.
Old Nov 17, 2004 | 07:51 PM
Troyer23J's Avatar
Guess i just have to put it apart to change.
What are you guys running for jets and adjustments on the air screw?
Old Nov 17, 2004 | 08:23 PM
scrambler123's Avatar
I always just pull it all the way out.
Old Nov 17, 2004 | 08:24 PM
Troyer23J's Avatar
off the intake boot? man, its a pain to get it back on there
what are you adjustments
Old Nov 17, 2004 | 09:39 PM
RAJ's Avatar
RAJ
I didn't think it was that bad. I was running a 280 main. I don't know what mods you have. The only thing I done was take the air box off, then jerk the carb off.
Old Nov 18, 2004 | 12:59 AM
i'm running the clip all the way dow and a 195 main.
