400 sport -- help!!
Old Nov 17, 2004 | 11:13 PM
Dynomike1's Avatar
Default 400 sport -- help!!
SUP Fellas, I just changed the front procket on my sport. After tightening the chain, i tightend the bolts on the swingarm and tooker for a spin. Ran great, of course, however the atv wanted to pull to right all the time. never had the problem prior to changing the sprocket. Any ideas? any input would be GREAT.. thanks guys.
Old Nov 17, 2004 | 11:29 PM
401's Avatar
401
Sounds like you might have a low tire on that side,hence pulling.There is no way to put the carrier in at an angle because the way it sits in the swingarm.
Old Dec 1, 2004 | 11:06 PM
rprice6's Avatar
Maybe the problem is one arm is shorter than the other? I have a friend that had a similar problem.
Old Dec 1, 2004 | 11:11 PM
Dynomike1's Avatar
ha.........ha.........ha..........ha.............. ..............................................ha
maybe i'll use my looong arm to turn off my alarm again!
Old Dec 1, 2004 | 11:16 PM
rprice6's Avatar
around 6am?
Old Dec 1, 2004 | 11:25 PM
RAJ's Avatar
RAJ
did ya find out what was wrong?
Old Dec 2, 2004 | 12:01 AM
ftwflh's Avatar
If you over tighten the chain and the bearings are bad in the housing it could pull.But check the tires first.What yr of Sport is it and are you tighten the chain correctly?
Old Dec 2, 2004 | 12:15 AM
RAJ's Avatar
RAJ
Check this.....my scrambler swing arm bolt was out, where it hooks to the frame. (on the right side) Everytime I would hit the gas it would pull to the right, I don't know if thats what swing arm bolts you are talking about. Before I found out what it was it broke off 2 teeth on my front sprocket. I had to put lock tite on the bolt to keep it tight.
Old Dec 2, 2004 | 12:05 PM
braveops's Avatar
dumb ? do u have to take the swingarm bolts out to change sprocket? i was thinking of changing mine aswell
Old Dec 2, 2004 | 05:38 PM
RAJ's Avatar
RAJ
No you don't have to. The front sprocket is a piece of cake to change. it's about a 5 min. job. I don't know about the rear, I never changed it.
