P700 rear suspension
Old Nov 18, 2004 | 11:19 AM
hiendtime's Avatar
Default P700 rear suspension
Have an 05 Team Green edition 700. Got about 15 hours on it and figured the rear suspension would have softened up a bit by now. Would like to make it softer. Anyone know how to adjust it? The manual instructs to take it to a dealer for adjustment? Any info would be appreciated.
Old Nov 18, 2004 | 12:15 PM
MikeRhyne's Avatar
You can adjust the spring preload yourself. There is a tool in the tool kit that will turn the nuts on the shock body. You will have to take the shock/spring assembly off to make the adjustment. Its pretty easy to do.
Old Nov 18, 2004 | 02:01 PM
SaskKawiGuy's Avatar
Use a metal punch or anything long & hammer to loosen the top nut. Then do the same thing to spring load, tighten back up but in reverse.
I find the 360 shock better for adjustment because the 700 is not a soft ride even after I reduced the preload.
Old Nov 18, 2004 | 03:52 PM
OuterLimit's Avatar
Kawasaki and EPI make a replacement spring for the rear shock, but they are both a "heavy duty replacement spring", and no softer rate spring is offered that I know of.
Works Performance can re-spring and re-valve your stock rear shock for about $260. They also make a replacement rear shock that can be tuned to your rider weight and riding style by Works prior to purchase. It cost $529.
Elka makes a replacement rear shock that is ultra adjustable, and pre-set for your weight and riding style as well. The Elka shock will give you the best ride, but cost the most as well, at over $900.
I would start by just backing off on your stock shocks preload, like you already had in mind. I just wanted to let you know of the options.
OL
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
