Warn 424 Cable Mounting Locations?
Old Nov 18, 2004 | 11:52 AM
SideWinder4x4's Avatar
Default Warn 424 Cable Mounting Locations?
Has anyone came up with any other creative places to mount the select cable/**** other than the top left side of the fender that Warn shows in its pictures? If so, please provide pictures if possible....or specific details at least.
Thanks!
Old Nov 20, 2004 | 10:24 AM
pat89's Avatar
We just installed one on my buddy's rancher and came up with an awesome solution to mounting it. We took a piece of aluminum plate and mounted it to the front rack via two u-bolts. It works like a charm and didn't require drilling into the plastic.
Old Nov 20, 2004 | 08:36 PM
CBR310's Avatar
mine came with a rocker switch that went on the left handle bar.
Old Nov 22, 2004 | 06:33 PM
robnhouston's Avatar
Oops, not the winch but a 424. Check out my links for my install. Not much you can do with the short cable. Keep up posted if you can find some new magic.
Old Nov 22, 2004 | 07:49 PM
CBR310's Avatar
sry thought you were talking about the winch.
Old Nov 22, 2004 | 08:39 PM
framer's Avatar
Just put the warn select on my Rancher,was wondering if anybody mounted the selector button on the handlebars.Would this affect the operation of the warn select.Almost looks like a factory install when I held it in place on the bars.
Framer
Old Nov 23, 2004 | 09:52 AM
JMO but I think the cable would be in the way of turning unless it was real close to the center. Then it's hard to imagine there is enough slack for that. If you could bring it up through the steering column area then your on to something, mount it next to the lights and key/pod. Only problem with that is the cable would have to make a big bend to get pointing upward again.
Pics always help if you have them..
Old Nov 27, 2004 | 02:46 AM
Daranello75's Avatar
I have a wolverine and I mounted it under the handlebars right over the gas tank. Look amazing. I didnt have to drill, I just took out the bolt holding the cab and bolted it in the same hole!
Dont put it on the handlebars because the cable is very sesitive to movement, ie mine only shifts if im sitting on the bike, if im off the 424 wont shift. Do a search on the yamaha page and would see pixs of the differant locations to mount
Old Jan 19, 2005 | 06:21 PM
Still haven't purchased a 424 yet, but can someone tell me how long the cable is so that I can get some idea of how far back I can mount the **** based on cable length? It will be going on a 2005 Honda Rancher.
Thanks!
Old Jan 19, 2005 | 07:27 PM
CBR310's Avatar
I put mine roght by the 12 volt acessory so I can still use it also.
