something i dont get with the 660s
Old Nov 19, 2004 | 12:08 AM
DarkManX's Avatar
Default something i dont get with the 660s
the Rhino 660, Raptor 660, and Grizzly 660 why is the rihno and grizzly all power and no speed and the raptor is both speed and tourqe crazy? in other words why if i get on a 660 grizzly then get on a raptor why would the raptor feel alot more tourqey if its the same motor?
Old Nov 19, 2004 | 12:12 AM
DuneRider650's Avatar
I ride a little here and there......
the weight difference
Old Nov 19, 2004 | 12:13 AM
TJw6981's Avatar
Tourque converters.... and they are set up for differant elements
Choky's Avatar
Weight and Gears,I guess... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 19, 2004 | 12:51 AM
RaptorOwner's Avatar
Yep. Try to put a honda accord 4 cyl engine in a hummer, see if the hummer has the same pep as the honda accord?
Old Nov 19, 2004 | 12:53 AM
lilnotts's Avatar
grizz and rhino are way heavier, plus don't they both use CVT transmission? if so i think you loose somethin like 15% of power through a cvt tranny, add porting, timing, cam specs, carbs, lotsa things make the difference
Old Nov 19, 2004 | 05:39 AM
RoostItUp's Avatar
lots of differences...the Griz and Rhino have one carb, belt tranny, weigh much more, shaft driven, geared totally different, different cam??, and im sure theres something else i forgot...you get the point though. All those equal less speed and engine pep for the utilities. Although I do believe they are built for more torque than what the Rappy has, but not raw HP.
Old Nov 19, 2004 | 02:37 PM
WISTECH's Avatar
You lose more than 15 percent through a cvt . Even the best gear type automatics can barely get down to a 10percent loss. The raptor has the most efficient driveline chain with manual. If it had an cvt it would be a gas guzzlr like the v force.
Old Nov 19, 2004 | 02:38 PM
rutelis's Avatar
the tq is differnt cuz the stroke on the piston is shorter on the grizzly there for giving it more tq then hp...the gearing is differnt and the weight to
Old Nov 19, 2004 | 05:19 PM
moldycheese's Avatar
there are a couple of diffrences with the actual motors
1. the electronics were changed to give the 4x4's more torque
2. the cams were changed to give the 4x4's more low end.
add that, plus a cvt plus another 200+/- pounds for the grizz, and more than that for the rhino, and thats what takes away the power
