Eton Viper90 mods
Hey im new to the site. I ride a CRF150, but my little brother is the one with the Eton and he needs sum more power. It is basically bone stock except a 13 tooth couter-shaft sprocket I put on it, so i was looking for sum cheap and effective mods
P.S. i heard you can tweak the cdi box on the 2005's more info on that would be appreciated
There is a dial on the 2005 cdi to raise the rpm limit, but what's the point if it just flat won't turn more rpms?
There is no such thing as cheap mods. Anybody says different is trying to sell you something. You can try venting the airbox and rejetting but I wouldn't expect miracles. Pipe and clutch kit would probably give the most effective gain.
Yeah I was looking at a hetrick racing pipe. But I don't undertsand how a clutch kit would get more power. and don't say there is no such thing as a cheap mod i got 3 more H.P. outa my dirtbike for only 30 dollars
To learn foundation information on how to obtain "more" performance out of your Viper, surf:
http://www.superflygirl.net/powerband.htm
Note: Applies to motocross engines but its base foundation does apply to quad engines.
http://www.off-road.com/atv/kidskorn...vupgrade2.html
http://www.off-road.com/atv/kidskorn...vupgrade3.html
http://www.off-road.com/atv/kidskorn...vupgrade4.html
http://www.off-road.com/atv/kidskorner/clutching1.html
If you turn your little brother's unit "into a rocket", he might NOT be able to handle it, or its stock suspension may NOT be able to hand it. Many people who upgrade their engine perfomance also upgrade their suspension system as well. I alway recommend people upgrade their suspension system first, then turn it "into a rocket." later.
For details on suspension system upgrades, surf:
http://www.off-road.com/atv/kidskorner/suspension1.html
http://www.off-road.com/atv/kidskorner/suspension2.html
http://www.off-road.com/atv/kidskorner/suspension3.html
In addition to these suspension upgrades, you may also need to strengthen the factory frame. It all depends how much "pounding" your little brother plans to do with his future rocket.
As mentioned above. All upgrades cost. You upgrade one part and its supporting part usually needs to be upgraded as well. Perform a few upgrades every QTR and within a few short years, its a rocket. Then, it's time to sell it and to a bigger frame unit. Unless you have a little / little brother to pass the upgraded unit down to.
Hope this info helps....
welll, i was doing the cdi box mod last night and i got in there, And im like where is the cdi box switch. So then i figured out my little brothers bike is actualy a 04, so then i cut the green wire. not that much of a difference though
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
