Size of the pilot..
Old Nov 20, 2004 | 06:31 PM
kwackermann's Avatar
Default Size of the pilot..
What's the size of the stock pilot jet on a 2001 400ex, and could that be the problem of it coughing and stumbling when wicking it open? Thanks [img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 20, 2004 | 07:20 PM
cals400ex's Avatar
stock pilot jet is a keihin 38. it is a 21 series if you go to replace it. what mods are done to the bike?
Old Nov 20, 2004 | 07:28 PM
hondabuster's Avatar
Could be...could also be the mixture screw is too lean. Or a vacumn leak in the intake area.
Old Nov 20, 2004 | 07:43 PM
.. The mods that have been done to the bike include total ditching of the airbox, replaced with an open element airfilter and a healthy Super Trapp pipe sans discs. Wow-- could a mixture screw do that?
Old Nov 21, 2004 | 12:59 AM
After all those mods...the jet is probably too small and the mixture screw wont compensate enough.
The procedure for adjusting the mixture screw, is to start about 2 turns out on a warm motor. Then slowly turn it in, til it drops in rpm. From this point count the number of turns out, til the rpms drop again. Midway is the spot to set it at.
If, however, you get to about 4 turns, ( from seated,) and, the rpm still doesnt drop....the pilot jet is too small.
Old Nov 21, 2004 | 04:56 AM
cals400ex's Avatar
you will need to change your jetting. it may even need like a keihin 155 mainjet. i would also see how it runs by moving the needle clip down one position. also, i would try a 42 pilot jet. the engine builders that i talk too seem to run the fuel screw up too 3 turns out and then get a larger pilot jet
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Chasso
Sep 19, 2015 03:06 AM
