snow plow install with lift kit/big tires
i just installed a warn manual snow plow kit on my p650.
when i went to hook up the cable for the manual lift it was
way short. it took a while for me to realize that with the lift and
26 inch mudlights that the front end sat way to high. i had to
sit on the front rack to get the springs to compress and install
the cable. so has anybody ran into this problem before? i hope
the extra pressure on the front springs is alright. i went manual
because there faster and there's no worries about the winch dieing
in the middle of plowing.
by the way the warn setup is cheap. i should have spent the extra
hundred and got the moose plow. by spring that cheap blade will be
bent all up.
bent all up.
