Aftermarket companies for Gas Gas
Old Nov 24, 2004 | 10:03 PM
JMaN04's Avatar
Default Aftermarket companies for Gas Gas
i have a 2004 Gas Gas WILD HP300 and i am ready to hook it up/add some aftermarket parts to it, but the problem is that i cant find any places to get after market parts for them and yet i see hooked up ones all the time. if u know any companies where i could find aftermarket parts for my quad please let me know. thanks alot and have a great day!
Old Nov 25, 2004 | 05:14 AM
dual-sporter's Avatar
LT-racing makes a powervalve cover, case saver, suspension links, water pump impeller, & other misc
Rebel Riders A-arms & swing arms
sand-tech racing sells a upper steering mount shim kit & other misc parts for it... swingarm converting rear to 250r parts (built by eyeball engineering)
world class racing makes narrowed A-arms
MX-tech does suspension re-valves/re-springs...(they make yuur shocks long-travel w/ this service)
motowest does motor work & builds a pipe/silencer
also check gasgasatv.com
there is also a company making a custom cross-over radiator & T-pin front suspension, but i don't recall who right now.
i'm sure there's more, but i don't recall which ones....
for cross over parts-
the wheels are honda bolt pattern, 4 on 144mm front & 4 on 110mm rear
the air filter is the same as a '97 honda CR250
the reeds are the same as replacements reeds for a rad valve for a 88-92 suzuki LT250R
the brake pads(all three pairs) are the same as a late model KTM dirtbike front pads
call LRD & see if they have decided to do anything for them yet... i haven't talked to them in a while.
what are you looking for?
Old Nov 25, 2004 | 10:16 AM
JMaN04's Avatar
i am looking for as of now performance parts, because the looks are pretty good as they are. but on gasgasatv.com Chad Duvall's HP450 looks really nice with the front like that and i want to find that hood. that gives it the extra racy look. i mean i think it looks 10x better, i dont know if thats the only thing he has to make it look like that but i like it alot.
Old Nov 25, 2004 | 01:23 PM
Diamondbird88's Avatar
Try these people http://www.proseriesper4mance.com/
Old Nov 28, 2004 | 05:21 PM
the hood on the 4 stroke tech gasgas is a quadtech hood for a z400.... & they used world class arms, w/ a mx tech re-spring/re-valve.
Old Nov 29, 2004 | 04:51 PM
JMaN04's Avatar
are those a-arms negative any inches? and does that re-spring/re-valve thing lower the front any or do the a-arms becuase it looks lower in the front.
Old Nov 30, 2004 | 12:52 AM
i believe the A-arms on the FST quad are -2" from stock, but the shocks are also zero preload, both will lower the quad.
call mickey dunlap at 4-stroke tech, (814)842-6159 for all the specifics, i believe now he has built two of them for his team... an '03 and an '04..... and i know he's done internal mods on the gasgas 450 engine as well...
Old Dec 5, 2004 | 03:07 PM
JMaN04's Avatar
what about any other companies that sell aftermarket parts? any more ideas out there? i need to find some companies to look into Christmas is coming and this is the oppertunity i have to get parts for my quad so if there is any other companies out there that u guys know of let me know. so far i have moto west for a pipe, got that down, lt-racing for the power valve cover and air filter, and a carbon fiber hood. let me know!
Old Dec 5, 2004 | 05:59 PM
definitely get the case saver from LT Racing. if you ever have a chain come off or break, it'll save your clutch cylinder too.
also, call the folks at Smackover Motorsports...(866) 342-7427 talk with gabe or jim, & tell them Andre sent you... gabe races a GG quad in XC events. they might know a few more links...
Old Dec 11, 2004 | 10:30 AM
JMaN04's Avatar
is Smack Over only for dirtbikes?
