dent problem..
Old Nov 29, 2004 | 09:26 PM
ishmael's Avatar
Default dent problem..
hey my trike has dents in the tank what is the easyest way to get them out i need to kno b/c im gona restore it soon, so i want to get them out
thanks
Old Nov 30, 2004 | 02:39 PM
catchmeifucan's Avatar
get a new one, its not worth fixin if its so bad that you have to fix it.
Old Nov 30, 2004 | 04:30 PM
Lomax's Avatar
Its simple, you can take a long peice of metal and lightly push on them from the inside and that will knock a lot of the dent out. To finish up the rest just fill it with Bondo to slick it up the rest of the way. The tank on My 185s looks great and it had 36 dings and dents in it and it looks great now.
Old Nov 30, 2004 | 08:53 PM
ishmael's Avatar
one reason i dont want to get a new one is b/c its like 150$ (from bike bandit), lomax is ok to heat the tank up to make it easyer to push them out and also what color of red did u use on ur trike???
thanks
Old Nov 30, 2004 | 09:47 PM
Ok, Ive discovered this, and Ill tell you why I posted that. I have found that if one person replies to a thread that nobody else has, even if it isnt correct, somebody will post the real answer in short time. So, the thing about buying a new one was all stupid just to get someone else to post.....it really does work, Ive done it a few times.[img]i/expressions/face-icon-small-happy.gif[/img] I really had no idea how to fix a tank......but Lomax did.....haha
Old Dec 1, 2004 | 04:58 AM
KNOWSALOT's Avatar
The Facility
A reputable body shop can remove your dents for very little money with heat activated glue and pull rod as long as the dent isn't close to a seam in the tank. It doesn't harm the paint at all and I haven't had one run over $50.00 yet. I have had a few done over the last two years and I am floored each time they come back. Technology has come along way when it comes to body damage repairs with mild steel.
Old Dec 1, 2004 | 06:25 AM
mrtrikes's Avatar
If your going restore your trike you,ll probably want to paint it ,so when it comes to the tank i prefer to use body filler .Heating up the tank will damage the protective coating on the inside and cause a rust problem down the track .If you try to lever any dents out be careful not to damage where the cap seals for obvious reasons.
Old Dec 1, 2004 | 11:37 AM
Lomax's Avatar
Mine was carried to a body shop and I just got to "veiw" some of the repairs in progress. I am not sure of the shade of paint that was used, I'll see if i can find out, I know that it matches Maiers red very well.. As for a Protective coating inside the tank, Get a KREEM kit and coat the inside of the tank before you paint it (this stuff can make quick work of paint) then your tank will have a nice liner inside that will never rust out so you dont have to worry about you work being wasted on fixing the tank.
Old Dec 3, 2004 | 09:02 PM
ishmael's Avatar
got anther question im gona paint my motor should i primer it befor i pait it righ?
Old Dec 4, 2004 | 06:43 AM
atcphil's Avatar
ive been told just use the highest heat resistant paint. if thats any help [img]i/expressions/face-icon-small-smile.gif[/img]
