sprocket question
Old Dec 1, 2004 | 05:54 AM
htloi's Avatar
Default sprocket question
to increase top speed do i need a smaller or bigger sprocket and if so,do i need to change them both?
Old Dec 1, 2004 | 08:27 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You would need a larger front or a smaller rear. A good rule of thumb is that 1 tooth on the front sprocket is equal to 2 1/2- 3 teeth on the back. Dont go to crazy or it may take you forever to reach top speed. The engine only has so much power. No you dont need to change them both. Just remember that a larger sprocket will require a longer chain and a smaller one will require a shorter chain.
Old Dec 1, 2004 | 11:57 AM
chubbysdad's Avatar
I am not questioning you but if you go smaller in the back, that would make it quicker off the line but slower at top end correct?
Old Dec 1, 2004 | 12:08 PM
KTM Patrol
Former Chinese POW!
No, exactly the opposite. Think of it as leverage ratio. If you had a 10 tooth front sprocket and a 40 tooth rear sprocket the ratio is 4 to 1. A 80 tooth sprocket would be 8 to 1.
8 to 1, rear wheel turns 1 revolution to engines 8 revolutions.
4 to 1, rear wheel turns 1 revolution to engines 4 revolutions.
Bigger rear sprocket gives the engine the advantage, but slower top speed.
Hope this help's.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
wendal
Sep 15, 2015 01:50 PM
