1987 Honda TRX
Old Dec 2, 2004 | 08:01 PM
Cody2552's Avatar
Default 1987 Honda TRX
Hey guys, I have a 87 honda 125 TRX, I am wondering what the ports are on the carburator. the bottm under the bowl i have no clue what it is. and there is one about half way up on the carb. then there is one that the fuel line is connected to. Please help. if anyone has a vacum diagram that would be great. Thanx
Old Dec 2, 2004 | 08:42 PM
WISTECH's Avatar
The one on the bottom is a bowl drain hose and the one on the side is a vent hose . I dont think they should be connected to anything. Just hanging downwards.
Old Dec 2, 2004 | 09:12 PM
Cody2552's Avatar
alright thanx. I have this other problem with teh carb. when i start the motor, the engine idles then goes high rev then back low then high for minutes on both low and high. i have a carb rebuild kit, just the o-rings. I have no idea whats going on.
Old Dec 2, 2004 | 09:48 PM
WISTECH's Avatar
Check for an intake boot tear or leak in the intake tract to the engine.
Old Dec 3, 2004 | 12:05 AM
beerburner's Avatar
Wistech is right on! Most likely a leak in the air intake somewhere. Too much air leans out the fuel/air ratio and it wants to run away. Just a trick I like to use.... (engine running fast) Get a can of fogging oil, using the extended tip, spray a little around the intake areas, connections, one at a time. Look for the rather thick spray to be drawn in, and some smoking out of the exaust. Engine rpm's will slow. More than one leak is possible. Locate and repair (replace) as you go. Hope it helps.
*Note to Wistech: I am a Badger too. Just signed up 2 night and It put me in Alberta as a user (default?). What was the major malfunction with that hunter? Makes me hurt for those guys families. Take care. bjb...
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
rgjackson
Sep 17, 2015 11:21 AM
stcspiderman
Sep 13, 2015 05:15 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
