Raptor Suspension Set Up
Old Sep 7, 2000 | 11:01 PM
racer_x's Avatar
I got in a few hours of riding tonight and hit a few small jumps to get a feel for the way its gonna handle in the air and lands. I'm 6ft. and about 200lbs. and it feels like it needs a little more rebound in the rear.
What I'm hoping to do in this post is to have everyone try different set-ups and then post what works and what doesn't. That way we can all learn from each other and save some time as well.
Old Sep 7, 2000 | 11:08 PM
YaMaRaPtoR's Avatar
did you adjust it at all before, mine feels good to me but they said they tried to set it up for me since im 6'3" 250lbs, I may be setting on a different reboud adjustment. They had asked what I weighed when they put it all together.
Its light huh, and it flies.
Old Sep 8, 2000 | 10:42 PM
racer_x's Avatar
I played with the suspension a little this evening.
The front shocks were in the third setting so I bumped them up to number four.
On the rear, the coil preload was in the middle and I turned it clockwise three turns to stiffen it up a little
On the rebound it was set at 10 clicks out. The manual says there is a total of 20 clicks but mine had 35. I set mine at 20.
Next I adjusted the compression damping. It was set at 7 clicks in so I tried it at max. and min. settings (12 clicks in & 1 click in) but I didn't feel any difference. I went ahead and set it a 10 clicks in for now.
I went out and hit a few jumps in 2nd & 3rd gear while getting about 10' - 15' air travel and the bike landed much better. Before the changes it was landing rather harsh. It's gonna be a matter of a little tweaking.
Hope this helps! Let me know if anyone else comes up with a good combination.
Old Sep 9, 2000 | 03:09 PM
paulb's Avatar
the standard setting feels perfect for me.
i am 1.85m 125kg.
Old Sep 18, 2000 | 03:51 PM
YaMaRaPtoR's Avatar
Well I want to amend my suspesion settings previously. Now I softened the rear. The rebound is at 14 clicks out and the sompression is at 5 clicks in, I also loosened the preload a couple of turns. the landings off of most jumps are very plush, I have yet to bottom it out. I may take the front up a notch from factory set because some times even though I dont bottom the front out, I will nose it low enough to drag the tips of my boots. But It feels excellent now.
Old Sep 18, 2000 | 04:15 PM
Bandit99's Avatar
I set my rebound somewhere near the max. I overshot my tabletop landing area by about 5 feet landing rear heavy. My butt was still coming down as my seat rebounded up. End result, my back hurts like heck. Oh well, live and learn. But I also dodn't notice any difference between the max and min compression dampening. The rebound makes a big difference! And I'm also going to add a few turns of preload. I've been hitting the skidplate on the ground of a few big jumps... and I'm only like 160 lbs.
I guess if I look on the bright side, if I had landed my banshee like that, the only wheeling I'd be doing would be in a wheelchair!!!
(as hard as i'v been on the suspension, nothing is tweaked... and i've put the nose in pretty hard!)
bmxatv10
Oct 14, 2022 06:23 PM
Robinhood
Dec 26, 2015 10:28 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
