Rubicon Oil Capacity
Old Sep 7, 2000 | 11:58 PM
P.J.'s Avatar
Anyone changed their oil yet? Following the manual's procedure, I ended up putting 5.4 qts in......about 2/10 qt more than the manual suggests.....no big deal.....just wondering what the rest of you have been finding.
Old Sep 8, 2000 | 01:08 AM
chilldaddy's Avatar
Mine held between 5.2 and 5.4 quarts. Thats alot of oil!!!!!
Old Sep 8, 2000 | 04:12 PM
Motorhead's Avatar
Wow, that's a ton of oil for a quad!! So does the Rubi use that engine oil in the transmission as well?
Old Sep 8, 2000 | 05:20 PM
hiofcer's Avatar
Yes, the transmission and the engine use the same oil. That's why the capacity is so much.
Old Sep 8, 2000 | 07:08 PM
alaskaweasel's Avatar
The manual said to put 5.2quarts in. However I noticed that after i put that amount back in it was a bit low after running it. I ended up putting about 5.4 or so in. So it sounds about right.
Old Sep 8, 2000 | 10:53 PM
REDGREEN's Avatar
MINE HELD 5.4 QTS. ALSO. SURE IS MESSY CHANGING OIL WITH TWO DRAIN PLUGS AND BOTTOM REMOVAL FILTER.WHAT OIL ARE YOU USING? I WAS GOING TO USE HONDA SYNTHETIC BUT OWNERS MANUAL SAYS DON'T USE OIL WITH MOLY ADDITIVES WHICH HONDA SYNTHETIC HAS.
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
