Blaster. Trenga rear Hydro modification
Old Dec 6, 2004 | 06:24 PM
Skidoomxz's Avatar
Default Trenga rear Hydro modification
I have a Trenga rear Hydro brake kit that is a lot better than the stock setup but not perfect. After a little bit of use I wanted more braking power. After I looked at it for a while I took the two bolts out and seperated the caliper. I made note of where it sat and the disc relation to that. I took a belt sander and sanded down the side that had to be brought into the disc, in my case it was the right side. I only took off a strong 1/16 of an inch and reinstalled the caliper. What a difference!! It locks up on pavement at will at speed. Hope this helps anyone with this kit or even the Blasterzone kit.
Old Dec 6, 2004 | 06:32 PM
Shav0's Avatar
The steel lines also provide alot better stoping power then the nylon lines.
Old Dec 6, 2004 | 06:35 PM
Skidoomxz's Avatar
yeah I have the tenth aniversary kit with stainless steel braided lines
Ridgerunner665
Sep 15, 2015 01:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
