Warrior carb. problem? Please help!
Old Sep 8, 2000 | 02:58 PM
Swain's Avatar
Ok i got out my 2000 Warrior for a normal day of ridin' and it was runnin' fine like normal for the 1st few minutes.All of a sudden it starts cuttin out real bad when i get on the gas.I then smelt gas and looked underneath and the overflow hose comin' from the carb. was pourin out gas.I started to ride back to the house and all of a sudden it quit so i kept ridin'.Well bout an hour later it started doin the same exact thing.And then once again it quit after a few minutes.Can someone please help me.Sorry for the long question but i dont know what it could be.My dad said maybe dirt got in the carb and the float was stickin.Thanks in advance!
Old Sep 8, 2000 | 03:11 PM
hot_shoe_cv's Avatar
Well your Dad may be right..He probably is most of the time anyway
Fuel pouring from the overflow usually means the the float isn't returning to a normal position & fuel continues to overfill the bowl. Or it may be the float valve that the float tang rests on. These little spring loaded valves can become clogged either open or closed, giving you both of the problems you've experienced. The first thing I'd do would be to pull the carb and spray the various parts; main jet, pilot jet, needle jet, float valve, etc., with a good blast of carb cleaner. Just to make sure the float level is at spec, measure the height of the floats.Button it all back up & prove your Dad right!
Old Sep 8, 2000 | 03:43 PM
Swain's Avatar
Thanx man i appreciate the help.I'm off to buy some carb cleaner im fresh out.So do i have to pull the jets out or just spray the whole carb.Thanx again.
Old Sep 8, 2000 | 04:05 PM
To save yourself from having to do it all over again, who not just remove the jets & blow carb cleaner thru them and follow up with a blast of air if you have a compressor.
Old Sep 9, 2000 | 04:12 AM
Swain's Avatar
Well i dont have an air compressor.Will i have to let it all dry out after i spray the carb cleaner in there or will it be ok to put right back together.And also how do you check the float height.Once again i am grateful for your wisdom!
Old Sep 9, 2000 | 02:08 PM
Since carb cleaner evaporates quickly, the only purpose in using air is to blow out any particles remaining afterwards.
After installing the float, float valve, & jets, turn the carb upside down to measure the float height. The measurement is taken from the surface of the carb body (where it meets the surface of the bowl) to the top of the float while upside down. The factory specs are: 11.4mm-13.4mm with the float tang resting on, but not compressing the float valve. If you do a lot of jumping and/orsteep hill climbing you may want to use the higher of the specs to reduce cavitation in those cases. If the level is out of spec, you adjust it by bending the tang ever so slightly where it meets the float valve, & measuring again.
Old Sep 10, 2000 | 11:05 PM
Swain's Avatar
Swwwweeeeeettt!
I took my carb. apart and holy cow!There was dirt in all kinds of places.How did all that gunk get in there?Well i sprayed the heck out of it with carb cleaner.Put it all back together and heck yeah baby.Rock and roll.She's purrin like a kitten now.I really appreciated your advice alot.
Thanks again!
Old Sep 11, 2000 | 01:14 AM
Dill's Avatar
might want to clean your air filter if there is all kinds of dirt in there.
Old Sep 11, 2000 | 01:19 AM
Now, for a little preventative medicine, an inline filter might be a wise way to spend a couple of bucks to save having to do it all again.
Old Sep 11, 2000 | 02:21 PM
Swain's Avatar
Inline filter?Would that be the breather hose that goes to the gas cap?Or do you put it in another location?Thanx again man!
