cold weather riding
Old Dec 10, 2004 | 09:41 PM
cerv's Avatar
Default cold weather riding
im about to change my oil on my 2005 660r,but i need to know if i should use a lighter weight oil for colder temps, yamalube 20 - 40 be to heavy? or does anyone use 5w-30,automotive oil.i herd that causes you clutch to slip, thanks for any replys.
Old Dec 10, 2004 | 10:03 PM
maddog56's Avatar
Only use oils specifically for wet clutches. As far as the weight I live in Michigan and have never had a problem running the same oil weight year round. I believe it was the same yamalube or eqivalent weight as you listed.
Old Dec 10, 2004 | 10:53 PM
rotty150's Avatar
here,here maddog, yama 20-50 is good year round
Old Dec 10, 2004 | 11:00 PM
7QuadSport7's Avatar
yah i agree with maddog just use ATV oil the auto oil can screw stuff up
Old Dec 10, 2004 | 11:05 PM
cerv's Avatar
thanx guys yamalube20-40 it is.
Old Dec 11, 2004 | 05:59 AM
BURKEDADDY's Avatar
heres some info about oil
oil link
Old Dec 11, 2004 | 10:04 AM
WindmillAtWork's Avatar
I think 20-40 is to heavy for cold weather. If most of your cold weather starting will be below 32degrees than I would go with at least 10W30 Yamaha Lube or even better their CW5W30 yamalube(CW stands for Cold Weather). Basically that will give the engine better protection at startup and still have protection once its heated up. Also it will make cold starting easier if you use the lower weighted oil. But if you plan on doing full throttle racing mainly then you would prob be fine with 20W40. I would probable only use that weight in summer when its hot out. Just my thoughts from reading tons of info on different oils. Now granted people have different options and you won't really hurt your ATV using any of those but different outside temps call for different weighted oils.
Old Dec 11, 2004 | 10:31 AM
Bosch's Avatar
You should go with the oil that is recomended in the owners manual.
Old Dec 11, 2004 | 12:01 PM
ss97's Avatar
Lets Ride!
I've been using YAMALUBE 10w30 all year
Old Dec 13, 2004 | 10:04 AM
I agree 100% Bosch! And you know what? In my Kodiak 450 manual they recommend all three weighted oils. Again they recommend the different weight oil for different temps. Thats why for cold weather I recommended the 5W30 like the manual does [img]i/expressions/face-icon-small-smile.gif[/img]
