Sport Quads Discussions on sport quads.
05 Predator
Old Dec 14, 2004 | 08:45 PM
660RaptorRida's Avatar
Default 05 Predator
heard some good things about the pred, havent ridden one yet, but i may be wanting to buy one and jus ride both the rap and pred, yall pred riders plz give me some info on this great bike..Thanks!
Old Dec 15, 2004 | 02:15 AM
RAJ's Avatar
RAJ
Default 05 Predator
What are you wanting to know? They weigh 415 pds dry, they are a power house, I but a 40 tooth rear sprocket on mine to pick up some low in tourqe. They are a great trail quad, even though they are wide. The wheel base is 51 inches, I think they are about 5 to 7 inches wider then the Rappy. They have 4.5 inches of ground clearance. And of course the 05 has reverse. I hope this helps you out, go to your local Polaris dealer and test ride on your self, just because I love mine don't mean you will like it.
Old Dec 15, 2004 | 11:49 AM
dfox's Avatar
Default 05 Predator
I only have a few hours ( less that 10) on my 05 Predator and so far love it. As with all things there are good points and bad points so... here is what I can tell you:
The Good points:
Very powerful and fast.
Handles good, very stable on trails, front end stays planted and flat, rear will break loose and slide predictably.
Great suspension.
Looks good over all.
Built to be strong and easy to maintain (Grease fittings where needed).
The bad points:
Bad (Ugly) finish on the engine (Barrel and head).
Electrical wiring is loose and looks unfinished.
Not as easy to ride as other quads ( I.E. Z400, LT250R) more effort required to ride trails. I haven't been able to figure out why but I have mussel soreness (Arms and shoulders) after riding the Predator.
Nothing is perfect and there will always be some compromises and room for improvement. My suggestion to Polaris would be work on Engine finish and wiring quality. Overall I am very happy with the Predator and feel I have made the right choice
Old Dec 16, 2004 | 11:50 AM
Squatcher's Avatar
Default 05 Predator
dfox, make sure you set up your suspension. It makes a big difference. The factory sets them up for a standard weight and on the Pred I heard that they don't have the suspension setup right. Check with the dealer or the forum to see the sag adjustment for that quad. I had to set up all my quads for my weight and riding style. You will like the quad a lot more once you do that.
Old Dec 18, 2004 | 11:12 AM
04predrider's Avatar
Default 05 Predator
I have an 04 pred i love it its a great trail quad but the gears need to be changed 1 gear is to low and 2 is to high. but I under stand they geared the 05's different so that makes a differnts
as for racing i haven't met any one who could beat me I've raced a raptor,kfx400,z400,banshee,and a yfz.
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
