rear axle bearings/whole rear end HELP!!!
Old Dec 18, 2004 | 11:49 AM
orky4969's Avatar
Default rear axle bearings/whole rear end HELP!!!
my '02 400ex for the past 2 months or so has been giving me trouble with the whole rear end. i ended up having to buy a new rear bearring carrier, where the axle goes through the rear swingarm. and latly either the axle nut keeps loosening up *fixed that i THINK* but once again, the rear end itself is loose, but i've only ridden it like 5-6x since everything went in brand new.. any help on, anything to check and make sure is tight etc. etc. PLEASE HELP!
thanks
Old Dec 18, 2004 | 11:56 AM
WISTECH's Avatar
Did you remember to reinstall the spacer that goes between the bearings,are you tightening the axle nut tight enough, jam nut,howare your swingarm bearings?
Old Dec 18, 2004 | 12:03 PM
orky4969's Avatar
basicly all of that is good .. i checked most of that last night.. i'l double check it again when i go out today... in like an hr.
Old Dec 18, 2004 | 12:53 PM
CapnMorgan's Avatar
are you sure you didn't over tighten the axle nut. If overtightened it will eat the bearings fast.
Old Dec 18, 2004 | 01:41 PM
orky4969's Avatar
how do i know if it is too tight? and how do i tighten it to the right "tightness" ??
Old Dec 18, 2004 | 01:59 PM
CapnMorgan's Avatar
Call the dealer. I just hand tighten mine then snug it with a pipe wrench but i have tappered bearings. I have a rad bearing carrier. I had one in my suzuki for 5 years with no problems so when I put my 400 together I bought one.$230 Complete
Old Dec 18, 2004 | 03:32 PM
orky4969's Avatar
sweet.. thanks
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
