Oil Injection Working????
Old Sep 10, 2000 | 05:29 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I just finished installing a Wiseco piston .020 over (GREAT COMPRESSION NOW) and I cannot tell if the oil pump is injecting oil. Normally the machine has a small amount of blue smoke in the exhaust but the exhaust looks very clear now. I am running a 100:1 oil mixture inside the tank to give additional lubrication for break-in (in addition to the oil-injection) so it really seams like it would be smoking even more than usual. I have run the engine for only 5 minutes so I have not hurt anything YET.
Before the piston installation the oil injection system was working perfectly.
Does it take a few minutes to get the oil up through the oil injection line since it was disconnected and may have air in the line?
Has anyone else had this ?
Help is appreciated.
Old Sep 10, 2000 | 05:38 PM
RickRitter's Avatar
Remove the oil line from the cylinder . Put a bolt in the hole to avoid an air leak . Make sure you have premix in the machine before proceeding . Remove pump cover and start the quad and let it idle . Manualy open the cable wheel on the pump . Observe the removed line. You should see oil oozing from the fitting ,if you do , things are probably ok . Double check your cable setting on the pump and replace the cover , reattach the oil line and top off the oil tank and keep a close eye on it to make sure it is consuming oil . Most likely , it is working .
Old Sep 10, 2000 | 06:13 PM
weedy's Avatar
I will give that a try. Does the new (higher compression piston) combust the fuel better which leaves less unburned oil (less blue somke)?
Old Sep 10, 2000 | 07:06 PM
RickRitter's Avatar
WOOPS .
I thought you had 400 . The pump is uncovered in the rear of the motor on you machine . No bolt on fitting either , just remove the hose from the press in fitting . The procedure is the same though .
The wiseco piston is the factory compression . It just feels higher because it is fresh and tight
Old Sep 10, 2000 | 11:18 PM
weedy's Avatar
OK thanks rick I will give it a try... will have to wait until tomarrow evening...got to give the little one a bath and to bed... thanks again.
Old Sep 11, 2000 | 02:22 PM
walexa's Avatar
This question to Rick Ritter doesn't go in this forum, but I'll ask anyway. Rick, what do you think about the injection system? Is it problem prone? I just bought a 2001 Xplorer 400, and am thinking about blocking it off and using premix. At 40:1, will the machine load up quicker than with the injection? What are the less than obvious pros and cons associated with either method of lubrication. The reason I ask you is that you seem to be very knowledgable on my engine, and I thank you in advance.
Waylan
Old Sep 12, 2000 | 01:01 AM
RickRitter's Avatar
Unless your quad is fairly well modified, I see no problem with your 400's oil injection system , it is adequate and reliable.
Where one can have problems is on a modified machine, modified engines have a larger appetite for fuel . The increased amount of raw gasoline can act as a *degreaser* to the engine , the fuel may actaully may wash oil off , leaving the piston to work in a bath of less than adaquate oil .
When premixing , the fuel is always a lubricant , the oil is already there .
On your stocker , a small amount of oil in the fuel would probably be all the added protection you would need .(While still using oil pump)
Oil pump failures are rare , the only one of Polaris models that had any failures in alarming numbers were a few 300cc models . The oil pumps are fine on most others . It is not pump failure I fear , but the failure of the pump (in good working order) to adequatly oil a modified engine.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
