Will the grizzly carburetor fit on the 450 Kodiak?
Old Dec 20, 2004 | 01:14 PM
RED5's Avatar
Default Will the grizzly carburetor fit on the 450 Kodiak?
Will the grizzly carburetor fit on the 450 kodiak (2003)? And if so will it make much of a difference?
Trying to give the Kodiak a little more kick.
Old Dec 20, 2004 | 03:24 PM
hondabuster's Avatar
The griz carb is designed to work with 660cc and a 5 valve head, the kodiak works with a 2 valve head.
That really shows up in the carb specs...griz has a 42 mm carb bore and the kodiak has a 33 mm carb bore.
If you did find a way to make it fit, you would loose so much low end torque, due to the velocity drop of the air flow, youd hate it.
Have you looked into aftermarket pipes and jet kit?
Its gonna be a disappointment too...because according to this graph, there is at most a 1 hp gain using a jet kit,
graph for kodiak, finding and using a high quality pipe, may add another 1.5 hp.
Pgbama11
Jan 16, 2016 08:19 AM
YankeeRebel
Oct 6, 2015 06:44 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
