Whats the difference in Carbs?
Old Dec 20, 2004 | 10:12 PM
Troyer23J's Avatar
Default Whats the difference in Carbs?
I was looking around EBAY at some random stuff. Started looking at Keihin Carbs. I saw a bunch of 39PWK carbs. Some from dirtbikes, some from 250r's. I know the HPD carbs have the adapter on the intake side for the airbox. What are the other differences?
Old Dec 21, 2004 | 12:21 AM
homdaddy's Avatar
none . the ones from hpd have the adapter and the right jeting where the others who knows what they are set up for. also hpd carb comes with the choke setup for the cable.
Old Dec 21, 2004 | 12:30 AM
braveops's Avatar
what is the adaptor?
Old Dec 21, 2004 | 07:11 AM
Troyer23J's Avatar
The side of the carb where the airbox goes. On the regular 39 it is alot bigger, the HPD has an adapter to make it smaller, if you look, you can see its a different peice of aluminum in there.
Old Dec 21, 2004 | 08:48 AM
braveops's Avatar
okay cool hey just to let ya know mine is from 600 or 700 sled and it works fine
Old Dec 21, 2004 | 09:00 AM
Troyer23J's Avatar
Cool. I just happened to be looking on EBAY and saw some going REALLY cheap, just wondering if they would work, for my next toy....
Old Dec 21, 2004 | 09:32 AM
CED's Avatar
CED
The carbs are setup totally different,HPD uses a different seat and a different slide,and needle.There have been a bunch of people on here that have tried running a non HPD carb and they just can't get it to run right.
Old Dec 21, 2004 | 01:34 PM
braveops's Avatar
well mine seems to run good if someone has a hpd carb get them to post what slide they have i think mine is a #6 and a eeh needle,35 pilot ,163 main
Old Dec 21, 2004 | 06:06 PM
homdaddy's Avatar
brave.
ihad one off my 700 on once and it had to small of a needle and seat when i would hammer it it would run out of fuel. so i got on for a quad. that is part of the reason sled have fuel pumps.
Old Dec 21, 2004 | 08:55 PM
braveops's Avatar
Originally posted by: homdaddy
brave.
i had same problem it was a brass pin i pulled it out and all is good (i had a fuel pump on and did the same thing ) thats how i figured it was that pin
Cole Hadden
Jun 15, 2025 09:05 AM
micheleLeigh
Jul 12, 2015 02:50 AM
cornermike
Jul 8, 2015 11:44 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
