Dyno jet or Dial a jet?
Old Dec 21, 2004 | 10:20 PM
Jspoon's Avatar
Default Dyno jet or Dial a jet?
What's the difference, just brand? I have an 05 Rancher, anyone using these?
Thanks
Old Dec 22, 2004 | 01:48 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Not the same things at all!
http://www.dynojet.com/
http://www.thunderproducts.com/dial_a_jet.htm
Old Dec 22, 2004 | 08:13 AM
Jspoon's Avatar
It seems like there similar as in atomizing the fuel up from the float bowl, all though I could be wrong. What's best to use? I live in Colorado and change altitude frequently?
Old Dec 22, 2004 | 10:30 AM
Red Rider
The Dynojet kit is just a set of jets and a needle, for rejetting your carb. Your Rancher is jetted for sea level at the factory, so you should rejet for your new base altitude (the lowest altitude you will be riding). If you bought it in Colorado, it may be rejetted already???
After that, you can do several things to adapt to altitude changes. The dial-a-jet might be a good choice for adapting to altitude changes, but I have never tried it, so I can't give you an opinion on how well it works. Magazine reviews have however been favorable.
Here is what I do! I live in the valley at 1,000', but I ride my local mountains and the Sierras, at over 10,000'. In one ride, I might see an altitude change of as much as 8,000'. It would be ridiculous to stop and rejet during a ride. So, I use the "TPI Valve" (http://www.thunderproducts.com/tpi_valve.htm). I have two of them installed in the airbox lid. As I ascend in altitude, I open them up for more air, then close them as I descend again. Above 10,000', I just pull the airbox lid off altogether. It is a system that works well!
What I am doing, is adding more air VOLUME, to compensate for the decrease in air density at high altitude. See this thread (http://forums.atvconnection.com/mess...word1=altitude)
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Cantbuytime
Aug 17, 2015 06:33 PM
